Suspension Choices
Old Oct 14, 2008 | 06:26 PM
vtmustangs's Avatar
vtmustangs
Default Suspension Choices
Alright so I decided to go with the 18in Black Shelby Razors now have to decide what to do with the suspension on a limited budget. I got maybe 300-400 to spend on the suspension right now. I don't want to drop it a ton just so there is no 4 X 4 look. So the chioces I have come up with:
1. Roush rear springs and roush rear shocks
2. A more conservative set of springs all around say Steeda UltraLites and wait awhile before get new shocks and struts.
With the second option may get D-Specs but would be a while before could get the money to pay for them so would have to ride around on stock shocks and struts for little bit.
Old Oct 14, 2008 | 06:27 PM
siberian.mist's Avatar
siberian.mist
steeda sport springs, get dspecs and adj. panhard later if you cant afford both at the same time
Old Oct 14, 2008 | 06:44 PM
vtmustangs's Avatar
vtmustangs
Well if I go steeda then I will check after I add them to see if I need a panhard bar but I could get that right away probably just can't find the extra 500 for the dspecs
Old Oct 14, 2008 | 07:10 PM
So_Cali's Avatar
So_Cali
300-400 May cover the D-Specs alone so either save up so you can get both or get some Tokico HPs if the adjustability isnt as important to you...
Old Oct 14, 2008 | 08:50 PM
vtmustangs's Avatar
vtmustangs
Well adjustability isn't that important just want some that will soften the ride
Old Oct 15, 2008 | 10:29 AM
drfister's Avatar
drfister
If adjustibility isnt an issue, go with what So Cali suggested. However I would highly recomend getting new shocks/struts with springs. Not only will it be less expensive to install both at the same time but it will ride properly. I had just rear roush springs and after a month and a half, I said 'F it' and went and got d-specs and pro-kit. Im sooo glad I did, its everythinig I wanted and more. Id just hate to see you spend money on something and then do what I did and realized you did something half-assed.
Figure out what you really want. Spend the money once. Enjoy.
Old Oct 15, 2008 | 11:46 AM
legendlime05's Avatar
legendlime05
i have the hp series on h&r springs, i would say stick to the hp, i didnt want the dspecs. bilstein also makes shocks n struts. as far as springs my pick is the h&r like mine or eibach
Old Oct 15, 2008 | 12:59 PM
ODDYSEY's Avatar
ODDYSEY
Site Moderator of Fury!
I put my FRPP N Springs on before I did any shocks/struts, ran like that for a few months. I would recommend getting some tokico's but it wont kill you to run with springs and stock shocks for a bit.
baddog671
Jul 26, 2016 01:20 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
UrS4
Sep 30, 2015 10:13 AM
marc954
Sep 29, 2015 11:18 AM
