For those with GT rear sways and poly bushings...
Old 11-07-2008, 04:51 PM
So_Cali
So_Cali's Avatar
Default For those with GT rear sways and poly bushings...
I'm having a little trouble with the bushings and I wanted to ask those of you out there that have this set-up... How do you get the damn poly bushings on the links?? LOL Any help is greatly appreciated here
So_Cali is offline
Old 11-07-2008, 06:21 PM
jimkaray
jimkaray's Avatar
WD40 and a vise is a big help.
jimkaray is offline
Old 11-07-2008, 08:50 PM
dyerjg
dyerjg's Avatar
I used WD-40 and a 2 pair of channel lock pliers, it takes a few tries but you'll figure it out.
dyerjg is offline
Old 11-07-2008, 10:21 PM
So_Cali
So_Cali's Avatar
Ok, I'll try that. How about to get the bushins with the metal ring, how do I get those off. Those are a pain in the ***! LOL
EDIT: Just curious, why use the WD-40? What does it do?
So_Cali is offline
Old 11-08-2008, 09:25 AM
dyerjg
dyerjg's Avatar
On those I cut the rubber edge off one end, heated them up with a propane torch and hammered them off over the top of a socket. Hope this helps.
dyerjg is offline
Old 11-08-2008, 09:27 AM
dyerjg
dyerjg's Avatar
also, WD 40 make them slip on easier. Use the lube that came with them when you put then back on the bar.
dyerjg is offline
Old 11-08-2008, 01:28 PM
So_Cali
So_Cali's Avatar
Thanks alot everyone, should have the sway on today after that little snag LOL
So_Cali is offline
mtgldr
02-03-2024 09:00 PM
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
09-16-2015 07:53 PM
robjh22
Suspension
09-08-2015 12:47 PM
RWHEELS
09-05-2015 03:42 PM
Quick Reply: For those with GT rear sways and poly bushings...
