05 stang coupe. Recently the gas guage has been just crazy. started out the guage would read about half tank, when i know it was full. Now the needle just points straight down all the time. When the key is off it even goes further counterclockwise. Someone told be that the sending unit in the tank maybe had sulfur deposits and to try a bottle of Techron and then a bottle of seafoam in the fuel. Tried both, neither worked.
suggestions? solutions?
Bob, have you noticed any moisture on your carpets? After a good rain, check the passenger side near the kick plate to see if your carpet is wet. There have been some issues with S197s leaking causing electrical problems. There is a TSB (Technical Service Bulletin) on this.
07.
thanks for the reply.
I'll check to see, but man we haven't had enough rain here in the past two months to wet a knat's back. Worth a try though, I'll check
thanks again for the reply!
Bob
Wrong. I have an 07 pony package and i dont have all these cool gauges. I made a post earlier about this on the forum. It's called "What are these different" or somthing like that
