traction control
Even with tc off in the tune, the rear end will still do its limited slip thing,, aka 'one wheel peel', as designed.
To get rid of that requires a rear end mod of replacing the stock differential with a t-loc or other carrier (true-trak, etc.)
https://mustangforums.com/forum/4-6l-v8-technical-discussions/494238-traction-control.html
here is what i found out about it its more common in the gts so I asked there. there is a link where you can wire it so its off until you turn it back on with a relay pretty easy stuff.
I agree with 157...while TCS is not a substitute for ESC, it can be a lifesaver. ESC can save an otherwise unrecoverable weight transition and I am really bummed we dont have it. We have all the parts...we just need the programming.
Other than the track...there is just no place to ever have TCS off. IMO, turning it off is about as bright as turning off your ABS. It just makes no sense.
It was slippery and I went into a slide, and mid-correction the TCS bit down, turning my correction into an over-correction and sending me into a guardrail.
I do agree it's best to just leave TCS alone when traction is poor however, as it's helped me get going quite a few times on slippery & slushy roads.
Anybody knows if different wheel sizes between the rear and the front (let say, 255/40X18 up front and 285/35X18 on the rear) can affect the traction control in some way? In this case front wheels would turn at about 786 rev. per mile and the back ones at 775.
I know this is not a big difference but if this system measure the difference between the revolutions of front and rear wheels maybe this will have some kind of an impact...
