Is this for the SN95 or the S197 variety.
And how did a Toyota get mixed up in all of this?
My Volkswagon had a rear differiential but it was
noting like the S187 differential.
guess that was a bad comparo as the toyotas are like the 9".
you shouldnt have to reset the back lash, a good how to you should be able to install an LSD DIY. gears are not a DIY mod tho
only differance between the s197 rear and the sn95 rear is the s197s is slightly wider, center section is the same
