rotor replacement
Old Mar 26, 2009 | 07:46 PM
thuxel's Avatar
thuxel
Default rotor replacement
I'm looking for some help on how to replace my front and rear rotors.
Anyone have a howto.
I searched the forum but no luck.
Old Mar 26, 2009 | 07:49 PM
jwog666's Avatar
jwog666
remove wheels, remove calipers, remove caliper mounting brackets, remove rotors. piece of cake.
Old Mar 27, 2009 | 07:58 AM
vtmustangs's Avatar
vtmustangs
Here is a write up a guy did when he changed his rotors and caliper brackets
https://mustangforums.com/forum/4-0l...-k-beware.html
Old Mar 27, 2009 | 08:12 AM
groved's Avatar
groved
Pretty easy, as posted above. But if you don't know what your doing use a repair manual. This may help (I'm sure you've seen it before) http://iihs.net/fsm/?dir=41
Old Mar 27, 2009 | 03:07 PM
157dB's Avatar
157dB
Cut & Paste Expert
You had better include 'remove the rotor clips' into your
tutorial or some greenhorn will be dead in his tracks when
he has the tires and calipers off but the rotors wont budge....
And you might as well also add 'jack up front end' to your
how-to-do-it list also or someone will remove the lugs without
removing the vehicle weight first.
Idiot Proof Tutorials are just not that easy to write up...
Old Mar 27, 2009 | 03:30 PM
davesyo's Avatar
davesyo
Just a suggestion .Buy a good brand of rotors .You don't want to go too cheap.
Old Mar 27, 2009 | 10:21 PM
thuxel's Avatar
thuxel
Getting them from Stage 3.
http://www.stage3motorsports.com/pro..._Shipping.html
Old Mar 28, 2009 | 12:33 AM
sonicmetalicS197's Avatar
sonicmetalicS197
Are you wanting to go drilled/slotted or just slotted or just plain?
Old Mar 29, 2009 | 01:37 AM
thuxel's Avatar
thuxel
Drilled and slotted.
See the previous post where I post the link from Stage 3.
Old Mar 30, 2009 | 04:49 PM
157dB's Avatar
157dB
Cut & Paste Expert
Holes are over rated and perform no function
except to have a place for a crack to start...
5.0muscle
Jan 11, 2016 01:17 PM
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
9550
Oct 26, 2015 05:01 PM
Omgitsa88Stang
Oct 5, 2015 07:33 AM
Wombatnation
Sep 13, 2015 09:16 PM
