Shaker 500 removal
Old May 19, 2009 | 10:52 PM
cherrycandy001's Avatar
cherrycandy001
Default Shaker 500 removal
Hey guys I'm going to be swapping out my shaker for a nicer one and have a few questions. The diagram says to remove "shift lever bezel" if equipped.
I'm assuming the "shift lever bezel" is the silver frame thing on the pic above. Am I right? How do you remove it? I thought maybe just popping it out with a flat head screw driver but I'm afraid to brake it. Also that little silver thing mid way on the right hand side, it looks like it pops off....what is it? Is it supposed to pop off?
Thanks for all your help guys.
Old May 20, 2009 | 12:33 AM
Sancho805's Avatar
Sancho805
you need to remove the whole plastic console. two screws are located under the armrest lid. when you pop up the entire console, the shifter bezel will pop up with it.
your best bet is to obtain some online installation instructions for any ipod adapter. you should be able to find some image diagrams. thats how i found them. it is basically a shaker removal. good luck.
Old May 20, 2009 | 07:46 AM
BigGameHunter589's Avatar
BigGameHunter589
Yep thats basiclly it, two screws towards the back of the armrest when it's flipped up. Than everything more or less just comes up when you pull up on the center console.
This is the guide I used
https://mustangforums.com/forum/2005...s-of-pics.html
Sancho and I did the same isimple install ( :
Old May 20, 2009 | 09:59 AM
157dB's Avatar
157dB
Cut & Paste Expert
http://iihs.net/fsm/?dir=377&viewfile=Audio Unit.pdf
http://iihs.net/fsm/?dir=441&viewfil...loded View.pdf
Old May 20, 2009 | 02:17 PM
Sancho805's Avatar
Sancho805
157db always got the hookup on info links
BigGame... how's your iSimple treating you? my unit has been doing its job very well so far. bout 4 months running. sound is perfect but navigation through shaker HU does require major league patience... lol.
Old May 20, 2009 | 06:25 PM
cherrycandy001
Thanks guys! I didn't realize that once I took the screws off the bezel would pop off. The diagram I looked at said to take the bezel off first. Ya'll are the best
Old May 20, 2009 | 08:03 PM
BigGameHunter589
my Isimple is doing fine as well, I'm two months in with no complaints. good recommendation my friend!
Old May 21, 2009 | 12:42 AM
maxshuty's Avatar
maxshuty
I've got a few links to the how-to process of removing the shaker 500, let me know if you still need them
Old May 24, 2009 | 03:06 AM
hataap's Avatar
hataap
i have a pdf on how to remove it if you still need instructions. they're great and easy to follow
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
