Need Help! Car Sputtering!
Ok, a little background first. I have an 05 V6 Vert. The only mod on it right now is a Magnaflow dual catback exhaust.
I have been having a big problem with the car sputtering and struggling for power for a while now. The problem happens after the car has warmed up and I try to take off from a stop or gain speed on the freeway. When it is cold the car runs fine. The problem can start after just a few miles sometimes longer. One night as I got onto the freeway after just 2 miles of driving the engine seemed like it was going to die and the CEL came on for all of 20 seconds then went off. It hasn't come on before or since.
I have replaced the fuel filter, removed my Airaid CAI and reinstalled the stock airbox, changed the plugs to E3's, and changed the oil. I have also cleaned the MAF and throttlebody. The battery was disconnected for a couple of hours during the work. I have driven the car almost 300 miles since then.
Does anyone have any suggestions of what to try next? I am a teacher and off for the summer so I have very limited funds to make it for the next couple of months. Any help would be greatly appreciated.
How many miles do you have on the car? Had you done any other work to it? How about fuel? Have you changed gas stations? Do you have the water leak issue? Your issues can be a number of things from fuel to igntion to corroded contacts at the SJB.
Powertrain warranty goes up to about 60k miles so i'd take it to a dealership and have them take a look. I was having a very similar sputtering issue and the dealership fixed it for free because the only problem was that my drivers side exhaust pipe right behind the cats wasn't hanging properly and causing a bunch of stupid vibrations.
