HELPPPP!
Old Jul 24, 2009 | 07:13 PM
BigNBad*88's Avatar
BigNBad*88
Default HELPPPP!
I bought a 2008 Bullitt in the u.s.a and brought it up to canada. For me to register the car it has to pass an inspection. In canada we need day time running lights. The trick is the head lights are HID lights and nobody up here knows how to hook up the drl lights with hid lights.
Any advice is greatly appreciated for i have a beautiful car that is sitting in my garage
Thanks
Old Jul 24, 2009 | 11:37 PM
wolfpup's Avatar
wolfpup
bow wow wow yippie yo yippie yay
my advice is to come to america...
Old Jul 25, 2009 | 12:18 AM
JCON's Avatar
JCON
2nd
Run a separate switch and tap in to something that is lit or running only when your car is on, don't know the relays yet. Or check and see if your Canadian counter parts have a different headlight switch, if they do buy one and install it.
Old Jul 25, 2009 | 06:02 AM
28HopUp's Avatar
28HopUp
MF Administrator
Thanks
You don't need to move to the USA. Couldn't you re-install a stock pair of headlights and have the DRL's wired up with those?
Old Jul 25, 2009 | 01:40 PM
157dB's Avatar
157dB
Cut & Paste Expert
Wow.
DRLs are dimmer headlights and HIDs cant be dimmed for DRL use.
Its not a different headlight switch.
Its a relay in the BEC with load resistors to drop the voltage to
the headlights for daytime use. Headlights off, the SJB puts the load
resistors in there with a relay in the BEC and headlights on, the SJB
takes the resistors out of circuit and applies full voltage with another
relay in the BEC.
Drill the housings and install a DRL bulb wired to run supplied power.
Fool the ol canadians or as mentioned above, silly law, just move to the states...
Old Jul 25, 2009 | 02:02 PM
Retrosolutions's Avatar
Retrosolutions
Former Sponsor
In Canada you do have to have DRLs, but they need not be running at n% to be legal, they just need to be on whenever the engine is on. You can hookup a relay trigger to turn the low beam HID on with ignition and it would pass.
Erik Prinssen
Mar 10, 2010 04:13 AM
wtfkey
Nov 7, 2008 11:06 AM
bigjwasup
Apr 2, 2008 05:00 AM
cholericfc
Jan 28, 2008 05:24 PM
