Help with Audio
Old Oct 23, 2009 | 10:44 PM
myarmy2007's Avatar
myarmy2007
Default Help with Audio
I have an '08 V6 mustang and anytime i plug in my zune or ipod into the port under the center arm rest and put the stereo on "line in" i can only hear out of one speaker, the drivers side front speaker, i even checked my balance and fade and both are in the center. please help i want to know how to make it so i can listen to my zune on all the speakers
Old Oct 24, 2009 | 07:55 AM
157dB's Avatar
157dB
Cut & Paste Expert
Check your 'patch cable' for proper connectivness on another line input jack.
Old Oct 24, 2009 | 08:14 AM
myarmy2007's Avatar
myarmy2007
yea i already tried that i bought two different patch cables and i still have the same result, hell its the same thing in my wifes 02 dodge ram 1500 both the zune and ipod only play outta one speaker the drivers side front speaker
Old Oct 24, 2009 | 08:47 AM
157dB's Avatar
157dB
Cut & Paste Expert
Jack is bad from side loading.
Get it replaced for free under warranty.
Cable is a 3.5mm MONO cable.
Get a 3.5mm STEREO cable with the three
conductor STEREO plug instead of the two
conductor MONO type.
Old Oct 24, 2009 | 10:01 AM
Sublime00's Avatar
Sublime00
I once made the mistake of buying a "mono" patch cable (Only one ring around each end of the plug). Does your cable have two rings around each end of the plug?
Old Oct 24, 2009 | 06:06 PM
chronos's Avatar
chronos
If it does the same thing in other vehicles then it's obviously not the cars problem. It's either the cable or the Zune.
JoshyGT
Sep 19, 2017 08:52 PM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
iamgobono
Sep 3, 2015 12:37 PM
iamgobono
Aug 16, 2015 10:50 PM
JJ94GT
Mar 18, 2004 09:30 PM
