help Wrong ecm type
Old Oct 25, 2009 | 02:27 PM
stoneblue's Avatar
stoneblue
Default help Wrong ecm type
I have an xcal2. tunes are from bama for the C&L. Tried to load the tune in car and got error wrong ecm type Any help Please. thanks FIXED. Email from bama, even if the sct tuner was retuned to stock, you still have to use the liveload to unlock it. Then the tuner should say unused.
Old Oct 25, 2009 | 03:01 PM
GrayPony's Avatar
GrayPony
Did you buy the Xcal from Bama? Is it a used xcal from an 07 or later car?
The ECM changed in 07.
Old Oct 25, 2009 | 03:09 PM
stoneblue's Avatar
stoneblue
I got the xcal from a guy at work. it was from bama. but it is older than 07. I did send an email to bama also.
Old Oct 25, 2009 | 10:45 PM
GrayPony's Avatar
GrayPony
You might try posting your problem in the forum on the SCT website. They are usually quick to respond.
Old Oct 26, 2009 | 08:54 AM
157dB's Avatar
157dB
Cut & Paste Expert
Your stangs stratagy codes dont match your
co-workers stang stratagy codes.
Old Oct 26, 2009 | 05:46 PM
stoneblue's Avatar
stoneblue
Default ECM code
OK. The sct was returned to stock be for I got it. I gave bama my ecm code from the sticker on the ecm, and my stratagy code that I read from my car. The only thing I can think of is the dealer may have reflashed the ecm with out putting the NEW Sticker on the ecm. I had the oil done and the recall on the airbag sencer. Thanks for the heads ip on the sct web.
Old Oct 27, 2009 | 09:59 AM
157dB's Avatar
157dB
Cut & Paste Expert
yep, ecm reflash and no update on the code sticker...
Old Nov 1, 2009 | 10:10 AM
stoneblue's Avatar
stoneblue
Default Fixed
And the C&L is in.
Attached Thumbnails help Wrong ecm type-c-and-l-0111.jpg   help Wrong ecm type-c-and-l-0131.jpg
Dokilar
15
Oct 16, 2015 08:13 PM
ChampInSD
Oct 2, 2015 04:55 AM
guitarman376
Sep 30, 2015 05:54 PM
mrappe
Sep 26, 2015 10:16 AM
