Foglamps anybody been able to get a dealer to program the Smart Junction Box
I sure would love to plug in a relay, a fuse, and add one wire to the Bussed Electrical Center(BEC) harness for my foglamps. My dealership sorta looked at me and blankly stared when I asked if they could do it.
All I would need is a ternimal to fit the bottom of the BEC for the foglight hot and hook one ground to the body.
If not I have built up an overlay harness with relays to emulate the function of the Foglamps function of the Smart Junction Box(SJB)
Feel free to email and specifics such as instructions for dealer and the terminal ends for the bottom of the BEC
tomtk3@wowway.com
tomtk3@wowway.com
Mine is a 2009 and I guess its alil diff I will double check today
The BEC has the sockets and the contacts are there both the relay and the fuse. I will pull the BEC today and double check the rest of the connections.
I had already checked the from the BEC to the foglight indicator and it is definately there. The other coil control goes to the SJB. I'll bet the wires from the SJB to the switch are also there...I mean the V6 lights are functional thru the SJB so I doubt they would micro manage the harness that much if the car has no FOGS to eliminate one or two wires in a harness. I migt be wrong them Hindu engineers at FOMOCO can be a unique bunch
What ya think check out the picture??
https://mustangforums.com/forum/memb...d-splices.html
Looks like in my 2009
Wiring from BEC to SJB to Switch is there. Contacts for the fuse and relay are in the box.
The only thing missing on mine is the output from the relay to the foglamps and of course the PROGRAMMING in the SJB
I already built the overlay harness but it sure would have been easier to plug in a relay, one fuse, run hot wire to output of relay at bottom of BEC, and program the function into the SJB. Would have only been two wire connections one to bottom of BEC and one to a body ground
BUT my dealer is not able to program the function into the SJB
Unfortunately Tom, I think you are going to have to think outside the box (outside the smartbox that is). I think you will be better off just making it into an independent system away from the OEM wiring. There's a guy in a different forum trying to do the same thing on a 2010 and he's coming to this realization. Following the factory methods are way too difficult and costly.
It seemed to me that the needed wiring and functionality was only half-way there.
Yes, there's a place in the engine box for a fuse and relay, and yes, the fuse, once inserted, feeds power to the hot-side of the relay, both to the energizer coil and one side of the relay switch contact.
The wire to the other side of the relay coil, needed to energize it, runs to the SMJ, and ends there. From the SMJ, there is a wire to the headlight switch to activate the fog lights (with a gt switch of course); the headlight switch grounds that circuit when on, and through the SMJ, grounds the relay.
I bypassed the SMJ by running the wire to ground the relay directly to the headlight switch (cutting out the SMJ altogether from the circuit). That allowed a GT switch to properly energize the relay when turned on (yeah, it's not using the SMJ to control it, but I dont care). That's half of it.
The other half was there was no wire to feed output from the relay to the foglamps. There is a small wire (orange I think) that feeds back to the headlight switch to turn on the foglamp-on indicator, but it's a small wire and not one I wanted to rely on running the fog lamps. I ran a separate wire from the relay out to the foglights.
So the parts missing were: smj not energizing the relay; wiring to the foglamps. And for parts, you need: a fuse (I used a 10A, but you could use 15 if needed); a relay; a switch to turn on the foglamps ( a GT headlamp switch is the easiest and looks nicest).
