Question....
Old Nov 10, 2009 | 10:42 PM
Kona6Stang10's Avatar
Kona6Stang10
Question Question....
As many of you know....I now have two GT mufflers....now
I have stock gt mids ....no over axle tubes.
My question is,
Will i need both over axle tubes from a gt or just the driver side tube?
And if so....I need to do ZERO cutting and welding correct?
Should just bolt right up?
Minus the DS hangers of course.... I know i need those lol
Please help!
Thanks in advance!
Old Nov 11, 2009 | 12:10 AM
Kona6Stang10
ttt bump
Old Nov 11, 2009 | 12:22 AM
scheetz83's Avatar
scheetz83
Hi
for my 05 i bought a complete gt exhaust off ebay for like $75 shipped. the Pipe was all one piece from the cat to the muffler. Odd that the 2010 changed that much that there are a mid pipes and a over axle pipes.
Old Nov 11, 2009 | 01:36 AM
Kona6Stang10
They are the exact same....with the exception of body panels and retuned suspension and interior.....sooooo It's odd that yours is different lol
Old Nov 11, 2009 | 11:33 AM
jtstakelin's Avatar
jtstakelin
Our stock exhaust setup is COMPLETELY different than that of a GT. You need an x or h pipe and two mids to complete the setup. I bought a whole kit for mine.
Old Nov 11, 2009 | 12:26 PM
Avalanch3's Avatar
Avalanch3
The V6 pipes are 2.25 inches while the GT exhaust is 2.5 inches, different tubing.
http://www.ninosport.com/Dynomax-Pip...5247-55248.htm
Old Nov 11, 2009 | 05:35 PM
Kona6Stang10
not for 2010....2.5 on all v6's this year!
and GT mids will bolt up in front.....MY Question IS.....
Will i need BOTH OVER axle pipes or just one?
Old Nov 11, 2009 | 05:46 PM
Joshspony's Avatar
Joshspony
My question is,
Please help!
Thanks in advance!
You say that you have GT mids, is that the crossover (H or X)? B/C you should just have a crossover, then tubing to go to the mufflers.
If the piping is the same size, as you said, then I would think that you would only need the drivers side. You may have to cut your v6 over-axle pipe a little shorted to account for the crossovers length. But the other side (being a take-off) should go right on.
Just my thoughts.
Old Nov 11, 2009 | 05:51 PM
Joshspony's Avatar
Joshspony
I just looked at NewTakeOff.com and found a picture of the exhaust. It is just an X, over-axle, then mufflers. http://www.newtakeoff.com/images/vie...d=8317&index=1
Old Nov 11, 2009 | 08:45 PM
chronos's Avatar
chronos
The pipes at the Cats are welded on aren't they? So this is not just a bolt on project. You have to take it to a shop to cut the Y pipe and put on the X pipe for you. So aside from needing the drivers side over axle pipe, you will need the X pipe or what are you going to hook it up to?
