Question....
Old Nov 11, 2009 | 10:22 PM
mustangbrewer's Avatar
mustangbrewer
!bump
Old Nov 11, 2009 | 11:08 PM
Kona6Stang10's Avatar
Kona6Stang10
Originally Posted by Joshspony
You say that you have GT mids, is that the crossover (H or X)? B/C you should just have a crossover, then tubing to go to the mufflers.
If the piping is the same size, as you said, then I would think that you would only need the drivers side. You may have to cut your v6 over-axle pipe a little shorted to account for the crossovers length. But the other side (being a take-off) should go right on.
Just my thoughts.
that's what i thought thanks!
Originally Posted by chronos
The pipes at the Cats are welded on aren't they? So this is not just a bolt on project. You have to take it to a shop to cut the Y pipe and put on the X pipe for you. So aside from needing the drivers side over axle pipe, you will need the X pipe or what are you going to hook it up to?
its the stock gt H......and the cats and all....will bolt right up to the v6 according to a friend who did the exact same thing.
.....so i'm thinkin all i will need is the ds over axle pipe?
Old Nov 11, 2009 | 11:17 PM
Avalanch3's Avatar
Avalanch3
I'm pretty sure you need to cut the Y-pipe.
Old Nov 11, 2009 | 11:46 PM
chronos's Avatar
chronos
Dude, that sounds pretty dam good. How the heck did you swing a deal like getting cats, pipes, and mufflers all for free? If you know anyone else that has a set up they want to get rid of, I'll take a set, and gladly pay for shipping.
Old Nov 12, 2009 | 05:02 PM
Joshspony's Avatar
Joshspony
You should be all good then. Let us know how it works out.
Old Nov 13, 2009 | 12:44 AM
Kona6Stang10
thanks guys!!!
I'll pm you if any of the tmc guys are giving stuff away again....
you can also look in the "trades and freebies" section at
www.tnmustangclub.com
bjames
Dec 31, 2008 08:10 PM
JalapenoNotch0
Oct 20, 2008 01:55 AM
seventhgear
SVT Forums
20
Oct 11, 2008 12:03 AM
thrift
Jul 1, 2008 11:04 AM
