Lower control arm replacement
Hey everyone,
I was at the official Ford dealership here in RI, and during a maintenance they told me my lower control arms were "showing play" - and that replacement would be a whooping $1090.00!
I guess my questions are:
How serious is the issue?
Is there a generally cheaper way to go about changing parts? (Order online, take to dealer, etc)?
If anyone is from around Rhode Island, a reference to a specific car repair shop that gives good deals would also be much appreciated.
Any help would be appreciated.
Thanks,
-DP
Thanks,
-DP
If you need new lower control arms just buy aftermarket ones (I have the HotPart.com set). It will be a lot less money than they are quoting you, will give you a much tighter back, and you can do the install yourself with jack stands in your driveway.
I'm pretty car-repair clueless, and I don't have a garage here in college unfortunately - I'm a foreign student here in the US.
I guess my best bet is to buy the part - or some compatible variant of it online? Then take it to the shop, and just get them to quote me for the man-hours required for repair?
it's that easy and you don't need a garage...just a flat parking lot or piece of concrete
Are they referring to the front LCA or the rear LCA? Back are cheap and easy to install...front will cost more and are harder to install.
Hey everyone,
Thanks,
-DP
Thanks,
-DP
You didn't say what year and how many miles, but there is a TSB on lower control arms. TSB 09 24 16 replaces both lower control arms to eliminate (hopefully) a clunk noise in the front end.
I've been battling a the front end clunk on my 07 since I bought it and I'm hoping this is the fix for it. I just picked it up yesterday and came straight home (to avoid the snow moving in) so I can't tell if it's fixed once and for all or not.
I think I'd check with the dealer and see if your car is covered. If it is...it's a freebie. $1090 sounds steep for for this job - then again, I believe both control arms are about $600 (just the parts).
