Trunk Ajar
Old Feb 2, 2010 | 06:55 AM
Chanda44's Avatar
Chanda44
Default Trunk Ajar
Well I went to open my trunk and heard a real long drawn out sound and when I try to close my trunk it shuts completely but it still says it's ajar. Any info on this topic
Old Feb 2, 2010 | 10:34 AM
157dB's Avatar
157dB
Cut & Paste Expert
describe 'long drawn out sound'....
Check to see if your trunk light is on with the trunk closed....
If so, try readjusting the trunk switch....
Or manually depress it and see if the ajar light goes out...
Old Feb 2, 2010 | 08:51 PM
chronos's Avatar
chronos
Maybe the stop bumpers are out of alignment causing the trunk to not close properly. They may be adjustable like the ones under the hood. I would have to run outside to look at them to be certain.
Old Feb 2, 2010 | 08:59 PM
Chanda44's Avatar
Chanda44
Sounds like the release is misfiring like clicking over and over again for like 2 or 3 seconds
Old Feb 2, 2010 | 09:12 PM
chronos's Avatar
chronos
Make sure your FOB isn't sending out too many signals. Maybe a weak battery is making it act up.
Old Feb 3, 2010 | 09:29 AM
157dB's Avatar
157dB
Cut & Paste Expert
Yea, sticky remote fob button.
Pull her apart and clean her.
Old Feb 3, 2010 | 04:26 PM
Chanda44's Avatar
Chanda44
But it's not just the FOB even upon pressing the trunk release from inside the car it does it
Old Feb 3, 2010 | 10:15 PM
chronos's Avatar
chronos
Take the battery out of the FOB and then try the trunk with the key. Open and close a few times and see what happens. That way you isolate the FOB as the issue.
Old Feb 4, 2010 | 03:57 PM
157dB's Avatar
157dB
Cut & Paste Expert
Wow, take that 2010 puppy back to the stealership
right away.....
pimp2303
Sep 17, 2015 08:45 PM
movielover40
Sep 15, 2015 10:37 AM
jink21
Sep 3, 2015 11:04 AM
MustangJourney
Sep 2, 2015 04:32 PM
inyadreems
Aug 21, 2015 09:10 AM
