GT Fog lights on 07 v6 mustang
#31
i used a relay to wire up mine which is the reason why i didnt need the switch and instead i put a little switch next to the light switch. and i am still kinda laughing at how this guy is upset. the whole reson i put that switch on there was for mustangmike to get it since he is the one that i thought needed a switch. sorry for all the drama, i think we are back in like 6th grade again...
#32
Relays are a GOOD thing. They are made for the "draw" that the lights/device will require, switches are not. With one, all the switch does is activate the relay! I originally had the aftermarket harness installed in our car with the supplied relay and fuse. I located the aftermarket switch that was supplied with the harness in the glove box. When I switched over to using the GT switch and the OEM harness that was in already in place in the car, I installed a relay and fuse in the factory spot in the BEC. In retrospect I should have installed the system this way in the first place, but the harness came with the grill and I was trying to save the cost of the GT switch.....when I found the one for $56 shipped, that motivated me to bring the system to OEM stock.
And its too bad I don't need a switch now, as I would have been all over your offer, Texas Stang!!
In my younger years, I have MELTED more than one cheap switch trying to get by with out a relay! Smoke and all!!!!
#33
#34
#101
bosch (tyco MADE BY BOSCH) IS THE ONLY REAL relay to use
#35
that would get my vote for a sticky sometimes the search on this forum sucks. But man 4 pages to get to it lol from the looks of it think the winstar uses the same light switch.
#37
I am not an electrician and I don't do electrical diagrams.
anwyay...
#38
Chuck, no sorry I haven't. I haven't had time at all. I pulled the switch out but when I take the time to go decipher 157db's diagrams then I will do the install.
