Gauge upgrade for X-Charger Xtreme
I've been putting off getting the couple extra gauges I bought for my ride properly installed, but with the Xtreme coming up, I figured it was time.
I added a Saleen pod to the dash. Rearranged my gauges (previously had Vac/Boost and Fuel Pressure in the SOS pillar pods. With the new setup, Vac/Boost moves over to the center dash, joined by a Wideband Air/Fuel, and the Fuel Pressure gauge over on the pillar gets an Exhaust Gas Temp gauge as it's new neighbor).
Getting the center gauges installed was quite "interesting" (in much the same way that stubbing your toe on a granite block would be "interesting") but I'm really happy with the result:
The downside is you MUST drill the dash, and if you're using anything other than the oddball very short gauges Saleen uses, you have to also cut a relief into the dash so that the back/rear of the gauge can recess below dash level. I made a cardboard template before any cutting was done, but precision is required. There isn't a lot of room on the sides for a screwup.
