V6 motor build help!!
I got permission from the wife to buy heads and cams so I was wondering are they easy to do myself I'm pretty mechanicaly inclined and do I have to pull the motor out to do it? And any other things that I will run I to doing it if I do it myself?
This is what LMengines.com said,
"We can port your heads.Stage I $295Stage II $495Stage III $1500Stage IV $1900 Cams would have to be a grind on your cores $595 Michael Thank you"
and this is what supersix said,
Stage 2+ heads: $1450 plus $300 core> Stage 3 heads: $1650 plus $300 core> Stage 3 heads require the use of a regrind cam that offers lift in the> .500-.510 lift range. right now we are not offering regrind cams for the 4.0> SOHC engine.> Cores: We add the core fee, if/when you return your orginal set of heads to> us, we refund the core fee. If you send your heads in to us up front, and we> port your original heads, then we would not charge the core fee.> > Forged pistons: $805> > Head studs: $425> > Add $90 for shipping> > Tom Yentzer> www.supersixmotorsports.com
