should I Flush
So I need a coolant flush. Ive never done one before, but i do want to learn. The only thing is I found a local shop that will do it for $40. For you that have done it, is it worth saving like $24. Not sure if the hassle is worth it.
Also do you guys use distilled water when you flush?
Oh and I got my car used, and Im not sure if the trans fluid has ever been done. How can I tell if I need it? FYI the car has 53K miles.
I would change ur filter when u do it
If it worries you (or the previous owner abused the cooling system somehow) then have it flushed. I wouldn't even consider it until at least 75,000 miles. $40 isn't bad for a shop to do it although you can probably do it yourself at about 1/3 the cost.
Tap water is fine IMO but nobody will stop you if you want to go buy however many jugs of distilled water you need.
If it's all brown and chunky it may be too late to just flush.
