should I Flush
Old Jun 16, 2010 | 01:45 PM
07 Stang's Avatar
07 Stang
Originally Posted by X3xMONGOOSEx3X
Haaa! That made my day!
OP, just pay the shop to do it. That way you won't have to mess with it and they will get it done correctly plus a lot faster too.
Old Jun 16, 2010 | 03:54 PM
157dB's Avatar
157dB
Cut & Paste Expert
nOT A SHOP.
tHAT RESULTS IN A LEAKY RADIATOR ASSEMBLY FROM WHERE
THEY WRENCH THE STUCK ON HOSES OFF.
fricken caps lock...
They cause more leaks than they prevent corrosion damage....
Old Jun 16, 2010 | 04:00 PM
stang1012's Avatar
stang1012
anyone know how to tell if you need a trans flush?
Old Jun 16, 2010 | 08:22 PM
rls82959's Avatar
rls82959
Thanks I needed that. LOL
Is your tranny shifting slowly, or is it slipping? I think the manual says 60k for the tranny fluid right? IMO, if your coolant is brown and chunky, you should change that and have the tranny fluid changed by a qualified mechanic.
Old Jun 17, 2010 | 12:45 AM
tx_zstang's Avatar
tx_zstang
i wont use 'flush' chemicals when doing a coolant flush; just run clean water though the system and let it drain. I''ll usually let the car run, radiator cap open, radiator drain open, and keep feeding water in the radiator from a water hose, keeping plenty of water in the tank while not overflowing it. Run the car about 5 minutes when it heats up enough to open the thermostat and circulate through. Cut car off, let water work through then stop and drain it all. Refill with antifreeze and distilled water.
For tranny, its a good idea to replace the fluid and filter. That's a little more difficult, and any reputable tranny shop or dealer should be able to do it for around $100 with fluid.
Old Jun 17, 2010 | 11:24 AM
157dB's Avatar
157dB
Cut & Paste Expert
The odometer and the scheduled maintance guide will tell you....
Unless your fluid is brown and burnt smelling....
Old Jun 17, 2010 | 06:09 PM
X3xMONGOOSEx3X's Avatar
X3xMONGOOSEx3X
Uhm you tell me
4cylinderplus2
Oct 9, 2020 07:45 PM
Nov 18, 2015 01:34 PM
wraith777
Sep 28, 2015 10:49 AM
Sep 10, 2015 07:23 PM
laserace
Sep 2, 2015 07:55 AM
