Rear Spoiler ???
Rear Spoiler ???
Hi,
Can someone please tell me the size of bolt required to mount a rear stock gt spoiler. I bought a used one, but the guy kept the bolts for his new spoiler. My stealership parts guy is as dumb as a dumb rock. All he could show me was a schematic that shows that he could only order the bolts if I ordered a new spoiler. Shees! And his little picture did not give a bolt size.
Thanks
Thanks
Did a Google search and found this;
M6-1.00, so that's what you need. However, you would also need to pick up 4 flat washers to go along with the nuts, because the OE nuts are the type that have a washer (maybe 1/2" to 5/8" in diameter) built into them.
Any metric fender 6mm bolt (10mm wrench) with built in washer will work.
Go to any junk yard and pick up a bucket of those, lol.
Doesn't matter which car it comes from... Toyota, other imports, who cares.
The OEM way is with studs and nuts.
Stealership can get them minus the spoiler.
Thats where I gots mine for my OEM spoiler install.
What did the guy keep them for?
To plug the extra orifices on his exterior?
M6.Uses a 10MM wrench.
You will need the 3M VHB tape and
such for a proper leakproof install...
Stealership once again.
Matt's 95 Stang
10-05-2015 07:16 AM
