Custom Intake Manifold Cover (Plenum)
As I stated in another thread about a month ago, I have been in the process of making my own custom intake manifold cover. It's finally finished and I'm posting the pictures here. (At least I hope they show up, its my first time posting pictures--so if there are any problems let me know). Its taken a while between school and work and everything else its just taken longer than I had hoped--but its done nonetheless! Any questions about the cover or anything else I'll be glad to answer
That was my thoughts exactly. I used the cover that was offered by Midwest Auto Gear as my platform then put my own twist on it. I took several measurements of the intake itself and made a general draft of what I wanted mine to look like. Then I made an entire cover out of noncorrugated cardboard (the stuff cereal boxes are made from), for fitment. Once that was made I was able to trace all my pieces onto the 22 gauge sheet steel I used for the body of the cover. The body is all welded together and ground smooth. The raised stripes are 5/8" x 1/4" bar stock I believe. There are nuts welded under the cover that the bolts run through the bars into. The same bar stock was used for all the mounting brackets. Two bars run straight down on the passenger side through the holes between the runners of the intake. A right angle bracket is then used to bolt through the two holes on the bottom platform of the intake and onto the two mounting bars running down from the cover. On the driver's side a single bar runs outside of the runners and utilizes a corner mount of the distributor. (the mounts actually are very rigid and strong and are hidden pretty well too). As for paint I used Rustoleum engine enamel and a aerosol can of factory code paint available on eBay through a seller named spraycansunlimited. I coated the entire thing with the primer and then base coat of black. I also ordered the mustang decal used on the front (which matches the font of the rocker panel stripes) from an eBay seller named phil145024ek2. I suggest their "short term" decal. It holds great for painting over and removes easy without leaving any residue. So after centering my decal where I wanted it on the black base coat I coated the entire thing with my factory color. I then removed the decal, which is why the letters remain black. The entire cover was then coated with the clearcoat engine enamel.
If you plan to undertake this project yourself, I highly suggest you look into painting techniques. I thought I had a decent idea going in, but just about everything that could have gone wrong with the paint went wrong lol, so make sure you have plenty of waterproof 320, 400, and 600 grit sandpaper. But in the end it turned out well.
Thanks for the compliments!!
Thank you. Ya I know some different color would have helped, but since my car is all sterling gray and black I didn't really know what direction with color I could have gone without making it look like it didn't belong. I've got a couple more under hood dress-ups planned, so hopefully it will bring it all together
Yea creativity gets your a long way, just look at your engine, and visualize what you want to change.
I made these this past weekend because I couldn't find anything better.
https://mustangforums.com/forum/2005...ire-clips.html
I had the same problem as you with not knowing what colors to use, so I took a chance and just did Ford Red (kinda looks orange).
As far as yours, you have a black canvas, so try getting some Ford Racing stickers and putting them on the sides of the plenum.
You also have those 3 plastic strips down the middle, you could make 1 blue, 1 white and 1 red and you would have the Mustang Pony logo.
such as this...
