Speedo Error
Old Oct 6, 2012 | 07:02 AM
Double Tap's Avatar
Double Tap
Originally Posted by Nuke
Back to the OP...
The onboards are not very accurate as I mentioned earlier. If you want to get a true idea of your average fuel mileage, begin hand calculating at each fill-up. I keep a cheap pocket planner (1 month per 2 pages) from WalMart in the glove box just for that and I also use it to log whatever I do to the car. You can go back and average each month for your best value for average fuel mileage. When I lived in the north, I would plot each vehicles monthly mileage and it was interesting to note the swings from summer to winter.
Yeah, I'm one of those **** engineers. Compulsive? Depends on the chick... or whatever.
Unfortunately your method does not take into account the inaccurate reading of the odometer. The first thing to do is use zero out the trip meter and do a run of ten miles as indicated by a GPSr. Now you can calculate to exact number of miles to use as correction factor for the odometer when checking the gas mileage. However there are other variables that will throw the calculation off. First would be that the tires wear as you use them, so the factor used to correct the odometer changes with time. Second is that you can't see how high up in the storage system the gas is so you might not be filling it to the same point each time. Third as related to the second the car has to be level and not on a small slope when refilling. Fourth The temperature of the gas at the time of refill might be dramatically different then the gas that was consumed.
So all in all for those **** compulsive engineer types this is a wonderful way to occupy their time and calm them down.
Old Oct 6, 2012 | 09:45 AM
Nuke's Avatar
Nuke
Double Tap, your hypothesis that the odometer is off, also, is correct. However, to keep things simple and since the amount of fuel used that the onboard calculates from is most likely the bigger of the discrepant variables, I suggest using the onboard odometer value in lieu of either calculating the odometer's error or replacing that value with a GPS-obtained value.
I need a nap.
Old Oct 8, 2012 | 11:31 AM
capndar's Avatar
capndar
But if it is all electronic these days ( and no mechanical connection between speed and odo)... is the odo necessarily off because the speedo is? I guess I will try to do a check this afternoon on the way home (assumng the mm's on the highway are close to accurate)
Cheers!
Old Oct 8, 2012 | 12:34 PM
Tex-stang's Avatar
Tex-stang
And you guys assume the GPS is correct?
Old Oct 8, 2012 | 05:12 PM
Nuke's Avatar
Nuke
You have to have SOMETHING to consider as a relatively accurate value. So what't the least of the evils? If you chose one (either the onboard odometer or a GPS) for your distance from fill-up to fill-up and you stick with that, you'll have good RELATIVE numbers, if not dead-to-nutz accurate.
Also, don't worry about the final number but use it to note any adverse trends. Even if it's inaccurate, it'll trend properly over time.
Old Oct 8, 2012 | 06:57 PM
Double Tap's Avatar
Double Tap
Default Yes it is
It is accurate to approximately 15 feet of actual location. That is truly amazing to me.
Old Oct 9, 2012 | 07:38 AM
capndar's Avatar
capndar
yes, trending is really what I am interested in, but did want to start with a relatively accurate number! Thanks
Old Oct 9, 2012 | 11:11 PM
snaf2u's Avatar
snaf2u
My vert`s speedo is about 2 fast at 75, my outback off by 3 fast at 75 and the wife`s impalla is actually correct per my GPS. The vert`s onboard milage is about 1 low, the outback is 1.8 high and the chevy is off by about 1.5 low. Pretty normal as far as I am concerned.
If you want better than that follow nuke`s advice.
Old Oct 10, 2012 | 12:27 AM
rbowmar's Avatar
rbowmar
My 05 base v6 also read 1.5-2mph higher than actual speed. When I switched from the stock 16" wheels to some used 17s that came with a set of p-Zeros, it read accurately. You can adjust your speedo with a tuner if you have one. Now you can justify getting either a tuner or some bigger tires!
Old Oct 10, 2012 | 06:36 AM
capndar's Avatar
capndar
Checked the odo yesterday - it reads between .4 and .5 low after 100 miles
mrtrodonet
Sep 19, 2020 03:12 PM
TCStangerv6
Oct 11, 2015 05:57 PM
zanemoseley
Sep 6, 2015 12:58 PM
Mr. D
Wheels & Tires
15
Aug 22, 2015 02:58 PM
