true?????
Old Sep 28, 2005 | 04:45 AM
02blackstang's Avatar
02blackstang
Default true?????
i have a 2002 v6 i heard that if you put a supercharger on it it will be fasrter then the v8 AND get better gas milage!!! Is this true? and about how much is a supercharger for a 2002 v6???
Old Sep 28, 2005 | 06:22 AM
hamidlmt's Avatar
hamidlmt
I ♥ Acer
Default RE: true?????
Try asking that very same question here:
https://mustangforums.com/forumid_1/tt.htm
Old Sep 28, 2005 | 12:40 PM
jthorn9's Avatar
jthorn9
The Godfather
First of all, post your questions in the V6, 2.8, Turbo forum so that you can get more accurate answers, this is a V6 forum, but your 3.8 and these 4.0s are quite a bit different. Yes you will be faster, as in have more accelleration than a V8, but they will still have you on the top speed end of the spectrum, unless you remove your top speed limitator, and still its kind of iffy. No you won't get better gas milage. If you put your foot all the way to the floorboard, you will wind up getting terrible gas milage. Reason is because you will be pushing more air into your engine and you will have to have bigger fuel injectors so, more air plus more gas consuption equals bad gas milage. Now if you install a sc and you drive your car normally you will see about the same gas milage as you are already getting. Sc kits only kick in a certain preset rpm, so you won't burn the extra gas until you hit that point. Now these kits vary in price, but normally a full kit starts at around 1200K to 1500 on ebay so they will cost you. Remember to get a true hp gain and have a true advantage over any V8 you need to do way more that a sc kit, such as a cai w/K&N filter, 73mm MAF, 70mm throttle body, 42% size reuction uderdrive pulley kit, a true flow dual exhaust system, either 3.73:1 or 4.10:1 gears, a t-lock, and use a handheld tuner to retune your ecu. If you have any questions on any of these upgrades look around in our V6 forum because we have already answered most questions pertaining to these mods, you will have to look through the first two or three pages of questions, but all the answers are there.
Granatelli Sales
Jan 20, 2020 12:34 AM
winner99
Sep 30, 2015 07:04 PM
treesloth
Sep 28, 2015 07:03 AM
2015Ecoboost
Sep 17, 2015 01:48 PM
TfcCDR
Sep 12, 2015 04:13 PM
