help picking new tires.
I'm wanting to get a new set of tires... Just very unsure on what size to get im currently running the stock tires (17inch rims) I'd like to run a wider tire just unsure on what to go with any help would be great. I'm going to probly just buy a set of 2 because only only two are worn down...
IIRC the stock 17" Bullitts are only 8" wide. The width is what will limit the tire width that you can safely install. I believe 255's is the max. Check the tire specs on sites such as tirerack.com and see what the recommended max is for an 8" wide wheel.
The Stock 17's on a V6 are 17X7, they are not Bullitt wheels on the 12's
KingRando
Oct 2, 2015 08:06 AM
mungodrums
Sep 28, 2015 10:54 PM
mungodrums
Suspension
Sep 24, 2015 10:12 PM
