Dual GT takeoffs--video/sound clip
RE: Dual GT takeoffs--video/sound clip
And was the factory driver side pipe necessary considering you also purchased a mid-pipe? Seems like kind've a waste if they cut it down anyway? Would the shop of fabbed something for you?
ORIGINAL: socool9004
Hey guys,
for the X pipe can i use like a GT one, like one offered from bassani's site...
Hey guys,
Update---found these: http://www.v6mustangstuff.com/05XPipe.htm This is probably what you were referring to? The answer still is "maybe, but I'm not sure."
....or do i have to buy the pipe and have it cumtom welded?
I suspect the JBA "true dual" (with H-pipe as I recall, so it isn't really a true dual) might be the closest to what you're wanting to do...
http://www.v6mustangstuff.com/05V6Exhaust.htm
I used the 2.5" stainless Magnaflow X-pipe (dealer on eBay) for $75.
No, it doesn't just pop in there--it takes a short piece of pipe on both sides that has to be bent to connect from the pipes coming out of the cats. So, it is patched in...
The best pics I've seen are from Afixer---I attempted to copy his dual setup. Look through this whole thread---it was my inspiration!
http://forums.bradbarnett.net/index.php?showtopic=34627
It turns out that my X-pipe sits towards the rear end a few inches more than Afixer's, but it doesn't seem to have created any problems.
ORIGINAL: ejnordstrom
Can not get to the sound clips you posted for the various muffler setups. Please check the links posted. Thanks
Check again later today, or tomorrow. They might even be gone for good from that site---if they aren't downloaded for some period of time, they are deleted from the system....
****UPDATE***
I just downloaded the first two files just fine...check again...
AmericanMuscle4.6GT
11-10-2015 02:06 PM
