2013 V6 FOG LIGHT WIRING HELP
Old 05-22-2017, 10:55 AM
block-carver
block-carver's Avatar
Default 2013 V6 FOG LIGHT WIRING HELP
A noob here to this site and to mustangs needing a little help.
I have been searching for days now on how to wire up fog lights.
Base V6 without fogs.
Purchased;
Take-off GT grille and fogs
GT headlamp switch
Starkey h11 to led harness/extension
Trying to wire the fogs up using the headlamp switch. I have found a multitude of posts, most using two relays and high beams. A lot of posts on here by 157dB, these have been very helpful.
Wanting to get input to see if the attached schematic is going to work. Any help would be appreciated!!
Thanks!
block-carver is offline
Old 05-23-2017, 07:08 PM
block-carver
Need help! Please!
I am missing something in the circuit?.
Old 05-24-2017, 01:56 PM
block-carver
For those of you interested, if any...
Second try was a no go.
I have studied 157dB's posts about fog light wiring more and studied the wiring diagrams for the 2011.
I did realize the switch wire is a ground out put as 157dB referenced. I haven't been able to find the fog relay wire that 157dB references though. Must be different for newer models??
I did find something in the diagrams.
Going to try a third time if I can find the fog light wire I am looking for. If, when I get it working I will post a new schematic of how I got it to work.
In the mean time if anyone has any input I would appreciate it.
thanks!
