Junkyard 2015+ 4 piston OEM brake caliper install on my 14 v6
Hi, I have 2014 mustang v6. I don't like my stock brakes. I'm thinking of trying to find the stock 4 pistons on the 15+ GTs and paint it and install it. The one that's made by brembo but doesn't have the baging as its oem. ( not sure its by brembo, correct me.) so need your help an advice.
would you recommend it ?
what would I need ? other than a 14 in rotor and new bads.. bracket ? booster ?
know anywhere I can buy it used ? cheap ?
any other suggestions ?
If they are not the 6 piston Brembos, the 18" may fit, no guarantee. The 4 piston calipers are not as large. If you are going junkyard, just get the whole setup, bracket, caliper and hose. Obviously, you would put on new rotors and pads just to be safe.
