Rear side Markers are out even after Bulbs replaced?
Anyone know what may be wrong? My brake lights all work fine but my rear bumper lights are out. Is there a fuse just for those lights? Or is there a bigger issue? Thanks
Depends....
Corrosion in the plug is one issue. Spanned contacts is another.
I usually put a dental tool behind the contacts to push them closer together
so they make better contact with the bulb base.
If the rear parking lights are on, then there should be power to those fixtures.
The wires run up to the rear tail lights, so trace back if you have to...
Depends....
It meantions a harness plug in the RH rear side near the tail light for the side markers and plate lights.. Quote here....
"All three of those things are on a wiring connector near the RH tailamp, inside the trunk. You must remove the large black plastic panel at rear of trunk to get at this connector. There are two connectors there, next to eachother. One goes to RH tailamps. The other connector next to it is for these three things, both rear side markers, and the license lamp. Connector has red wires, green wires, a black wire. Maybe this connector is not connected ? Could be if body repairs were made. check this lst and get back to me if this is not the problem. there are also two black ground wires in this same area of trunk...but they go to other things also, so most likely not a ground problem.
My rear trim is kinda loose so I peeked into it and sure enough there is a plug that is not plugged up just like the picture the guy posted in that thread. I couldn't see the plug that connects to it from the small opening. Ill need to remove the panel and ATM I can't due to rain. I hope this is just a simple fix and not something bad.
This isnt my picture this is the same plug that isn't connected on my car as well. http://www.allfordmustangs.com/forum...130_130439.jpg
Well I figured it out. The plug was not hooked up and was down inside the bumper cover. Managed to route it back up but it must of been wrapped around something because it would not reach the plug. So instead of the hassle of removing the cover I just cut the connector and made the cables longer and wire the connector back up. Now both side markers and plate light work. I wrapped it in black tape and wire loomed it and wire tide it, looks stock almost. xD
BryantHavercamp
05-25-2009 10:51 AM
that_guy_trav
08-22-2007 07:37 PM
v6 muscle
06-15-2007 11:59 PM
GTstangB.F.D.M.
05-12-2007 06:07 PM
