control arm/tie rod end replacement questions
Old 02-22-2019, 02:07 PM
650mark
650mark's Avatar
Default control arm/tie rod end replacement questions
hi all, new guy here. just bought a beautiful '05 convertible that needs lower control arms and tie rod ends. have all the parts and a fair amount of mechanical savvy but asking if there are any pitfalls to look out for when doing this job. i've seen a couple of videos and it looks like it's not rocket science but youtube videos are usually worth what you pay for them. open to any suggestions from forum members that have actually done it. thanks
650mark is offline
Old 02-22-2019, 09:46 PM
bl817
bl817's Avatar
not much to it as you've found out. for the fronts, you don't need to mess with the steering rack. just turn the wheel all the way to the opposite side your working on and you can move the boot out of the way to get the front bolt out. use a chisel or something like that to "spread" the knuckle away from the lower ball joint, after you remove the bolt of course, itll fall right out. the rear lower control arms are basically a RR. the upper takes a bit more work but not terrible. welcome to the forum, enjoy your pony and good luck!
bl817 is offline
shawnmm12
09-27-2018 12:51 PM
ghunt
10-28-2015 01:42 PM
Djohnson3000
02-21-2014 03:27 PM
Toddman0025
06-18-2009 12:19 PM
suzukidragracer
03-23-2006 10:00 PM
Quick Reply: control arm/tie rod end replacement questions
