Trans/shaft noise when powered at 50+ mph?
Old Jan 30, 2022 | 06:45 PM
MU5T BU5T's Avatar
MU5T BU5T
Default Trans/shaft noise when powered at 50+ mph?
Car's been sitting a lot for a few months and it's the middle of winter in MN. Finally got it fixed enough to do some highway miles and I'm getting this fairly pronounced rotating rubbing/friction noise, about 6 times per second at 70mph, and isn't very present below 50. Sounds like it's centered between the front seats. Stops when I let off the gas. I'm assuming it's the U joint or shaft bearing but I'm a hobbyist at best, anyone got other ideas? Any way to test if it's a worn gear? It has 300k miles on it, no idea when the driveline was serviced last but it was always serviced at every interval at Ford. Thanks.
JMono
Nov 19, 2009 08:52 PM
Jet Driver
Apr 20, 2009 07:13 PM
wesleyn
Mar 10, 2009 10:18 PM
1quik69
Aug 16, 2006 02:07 AM
BoyceCat03
Aug 17, 2003 02:41 PM
