quick question about gears and trac lock
hey i just called a service guy about my gears and t lock. he said to do it he needs these things and someone help me please find these online cuz its holding up my install
carrier
ring & pinion kit
bearing/installation kit
pinion seal
pinion nut
2 axle seal
im totally lost now
thx all
carrier
ring & pinion kit
pinion seal
pinion nut
2 axle seal
im totally lost now
thx all
RE: quick question about gears and trac lock
ORIGINAL: jebrewni
carrier
ring & pinion kit
pinion seal
pinion nut
2 axle seal
im totally lost now
thx all
carrier
ring & pinion kit
pinion seal
pinion nut
2 axle seal
im totally lost now
thx all
The "carrier" is the TracLock
You should be able to get an installation kit (bearings, seals, etc.) from the same place that you got those, e.g. http://www.ring-pinion.com/default.asp?pid=2&pageid=76
BTW - properly setting up a rearend is not something that should be entrusted to any old shop, including (most) dealerships. You might consider looking for a specialty shop in your AO.
ORIGINAL: Scrib
The "ring & pinion kit" = gears
ORIGINAL: jebrewni
carrier
ring & pinion kit
pinion seal
pinion nut
2 axle seal
im totally lost now
thx all
carrier
ring & pinion kit
pinion seal
pinion nut
2 axle seal
im totally lost now
thx all
musnicki
09-23-2015 07:11 AM
09-03-2015 07:14 PM
09-01-2015 08:16 PM
