0-60 times manual vs auto
RE: 0-60 times manual vs auto
ORIGINAL: chrisc65
Check this out...
[IMG]local://upfiles/15877/C5224E21BCAF4CE5B88ACBAE2EFDFA51.jpg[/IMG]
Check this out...
Ford likes their automatics to shift very smoothly... way to smooth! In stock form the automatic will retard the timing big time when the tranny shifts to decrease power and make those shifts silky smooth! If I remember correctly it they pull almost all the timing! Car goes from like almost 30 degrees to 0... I had a graph at one time showing it...
So a stock automatic is going to be probably about .3 to maybe .4 slower in the 0-60 time...
Now... here's were it get's interesting... I had Lidio set my shifts to "Barbaric"! My shifts are fast and hard! Lidio's hard shifting shaved .25 off my 0-60 time vs the x-cal2 I was running...
Take a look at this graph and you can see how fast Lidio's shifts are compared to "other"... you can also see where the wheels "chirp"....
ORIGINAL: stang13
What programmer did you use? Just curiouse
ORIGINAL: StickDriver
This is my best pass from Saturday the 14th in my wifes Mustang.
r/t 60` et mph
.117 2.099 13.845 100.19
r/t 60` et mph
Its all stock. Shift @ 5800 rpm. Kinda sketchy on launch with manual trans and not consistant. Just barely lifting between shifts.
RPM`s up to 2000K at deep stage. I let the clutch out hard but no sidestep.
