Need help can't burn
RE: Need help can't burn
ORIGINAL: stangman53
O.K. you rest your case but Bama chips a long way from me
You have done a nice job on your car and I enjoy your website. I am in N.Y. so its a distance I don't have the sheet but I am going back aweek from Monday. Do you think Lidio would talk to my tuner Dan Carlson. He may even know him from his 10 years at steeda.
So what your saying is from a dead stop it flattened out for a split second and then took off. Or it just had little response like when it was stock
Would be interesting to see your dyno charts and the A/F if you can, when you get them... I would think it's got to be in the Torque Managment System or perhaps with the delay between when the car goes from closed loop to open loop... (or is it open loop to closed loop?) LOL!
well with the auto the car has the tendancy to upshift a lot
so if you mash it and you are on 5th, you are not going to feel very much, so what you might want to do is pull it down into 3 right before you hit it. if you are going too fast for 3rd gear, turn off over drive right before you hit it, and that should put you in 4th gear. then gas and right before it red lines shift back into D (5th gear)
always works for me, and i am on stock tune
I follow what you are saying but on the parkway while doing 60 if I mash it it takes off like a r----d ape. This problem is strictly from a dead stop or going around the on ramps on lONG iSLAND. Otherwise the car flies
