Speedometer
Old Feb 24, 2006 | 03:35 PM
whtstangverto5's Avatar
whtstangverto5
Default Speedometer
Does anybody else think they have this? I believe that my speedometer is way off. When I'm going down the highway, I'll look to see that I'm doing between 75 & 80, yet I'm not flying by traffic and some peolpe still pass me.
I read an article in Car & Driver about a year ago about the manufacturers having a 2-5% error. Well 5% at 75 is only 4 MPH and I don't think I'm doing even 70.
Does anybody think that Ford might have calibrated all their Mustang speedos for the GT's 17" rims in a cost saving method to avoid a recalibration for the V6's 16 inchers?
Old Feb 24, 2006 | 03:51 PM
hamidlmt's Avatar
hamidlmt
I ♥ Acer
Default RE: Speedometer
It could be that individually, your speedo is just off. Or, there's a lot of fast drivers in your area!
Old Feb 24, 2006 | 03:59 PM
whatdaproblemis0's Avatar
whatdaproblemis0
JUST DRIVE FASTER
Old Feb 24, 2006 | 04:02 PM
whtstangverto5
I'm thinking of having a cop I know give me a call next time he sets up a speed trap in town so we can test it out a few different speeds.
Old Feb 24, 2006 | 05:55 PM
Moonbaby1973's Avatar
Moonbaby1973
If it helps, i recently posted a question about switching from my stock 16" rims to stock 17" wheels. My question was will i have to get my speedometer re-calibrated. I had a few people reply that the outer diameter of the 17" tires used on the 17" wheels is actually the same as the outer diameter as the 16" tires. Even though the rims are bigger, the sidewall of the tires used is a lower profile making the outer diameter the same. So, in theory, this should not have any impact on the speedometer. hope that helps.
Old Feb 25, 2006 | 01:13 AM
LesteR723's Avatar
LesteR723
ORIGINAL: Moonbaby1973
i can vouch for that... i got my 17" takeoffs from saleen, and when i was putting them on i decided to take a look- and they were the same height. Needless to say the take-off's were wider... and better looking, but same hieght=no speedo calibration.
Old Feb 25, 2006 | 01:26 AM
StreetRod Steve's Avatar
StreetRod Steve
"i can vouch for that... i got my 17" takeoffs from saleen, and when i was putting them on i decided to take a look- and they were the same height. Needless to say the take-off's were wider... and better looking, but same hieght=no speedo calibration."
Well I also bought the Saleen GT take off Bullitt rims and Pirellis, and after I took off the 16" stock BF Goodrich tires, I had to raise the car another 1" or so with the jack before I could put the 17" tires on the lug nuts. That makes the think the overall height with the 17" tires is indeed a bit taller
Old Feb 25, 2006 | 03:46 AM
Puleo76's Avatar
Puleo76
my speedo is just fine after the 16 - 17 inch change...
Old Feb 25, 2006 | 10:10 AM
LesteR723's Avatar
LesteR723
ORIGINAL: StreetRod Steve
did you set the tires on level ground next to each other? I did and they were almost exactly the same
Old Feb 25, 2006 | 11:49 AM
gtcs1's Avatar
gtcs1
Hi,
The 16" (BF GOODRICH TRACTION T/A 215/65/16) dia is at 27" and the 17" ( Pireli P-Zero Nero tires size 235/55/17 ) is at 27.2" .
That means only 7/10 of 1% on circumference, meaning at 75 MPH stock, with the 17", you'll go at 75.5 MPH, peanuts.
If you want to find out tire comparaison, go to this site where you can compare your stock size versus any other, you'll find many valuable infos. Have fun
http://www.miata.net/garage/tirecalc.html
GTCS1
articman
Jun 21, 2018 11:45 PM
Mr. D
Wheels & Tires
15
Aug 22, 2015 02:58 PM
Nurdyguy
Aug 21, 2015 10:23 PM
danclint
Nov 28, 2004 10:32 PM
Leadfoot
Sep 10, 2004 03:05 PM
