New wheel problem
Old Aug 22, 2007 | 08:31 AM
smokenpony's Avatar
smokenpony
Default New wheel problem
I just bought a set of used zenetti 20" wheels with nitto tires with about 10,000 miles on them. My problem is that I have a shimmy between 40 and 50 mph. I was told that this could be corrected by installing a spacer. Both front wheels are balanced correctly. Will the spacer work or do I need new tires?
Old Aug 22, 2007 | 11:49 AM
colin@tirerack's Avatar
colin@tirerack
Default RE: New wheel problem
It may be that they are not hubcentric. Most of the time a ring is used to adapt the wheel center bore to the hub. You may have an incorrect ring size.
Old Aug 22, 2007 | 11:16 PM
Stoenr's Avatar
Stoenr
Also might want to check the clip on 1 stud of the rotors. Some aftermarket rims dont allow for space for that clip to fit into like the OE ones do. Simply remove the clips and go for a spin.
[IMG]local://upfiles/17179/29AD9C73E53F45F08763384B2337497C.jpg[/IMG]
mstahoo
SVT Forums
Aug 19, 2021 09:15 PM
NorthAmericanTuning
Nov 9, 2016 11:44 AM
musnicki
Sep 23, 2015 07:11 AM
5.0 kevo
Sep 3, 2015 06:24 PM
