Stripped lock
Old Jun 30, 2008 | 06:55 PM
lcdt94's Avatar
lcdt94
Default Stripped lock
So about a month ago I sprayed the threading of my left rear wheel with wd-40 because a squeaking noise would occur from that general area while i drove slowly with the windows down. Being the dumbass that is myself I didn't account for the reduced amount of torque that would be necessary to tighten the lug nuts back on. Now I almost can't get the locking nut off, what should I do?
Old Jul 1, 2008 | 07:20 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
Default RE: Stripped lock
Sounds like you torqued the lugs AFTER you applied the WD-40, so it is now super-tight? I don't have any solutions other than to just keep trying. If you get into real trouble, you can take your car to a tire/wheel shoppe to remove them for you.
Justlike the mafia...... 'they have ways of making you torque' [8D]
Good luck, Jazzer
BOB ROME
Jul 26, 2023 01:54 PM
guitarman376
Sep 30, 2015 05:54 PM
GLOCKer
Sep 28, 2015 07:36 AM
Sep 25, 2015 06:58 PM
