help with sizing for wheels
Old Aug 15, 2008 | 06:56 PM
EMichael's Avatar
EMichael
Default help with sizing for wheels
what size tires would you put on 19x9 and 19x10 wheels? anybody have any pics of their own or something to give me an idea? thanks in advance for the help.
Old Aug 15, 2008 | 07:48 PM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
Saleen runs 275/35/20"s up front and 275/40/20"s out back on their 9"s & 10"s.
A 275 is quite a bit of tire for a 9" wheel, but will fit. Most will recommend 265's and 285's for the 10"s, and what I would recommend.
Jazzer
Old Aug 15, 2008 | 08:39 PM
EMichael's Avatar
EMichael
well would this be the same for a 19" wheel? and also when you say 275 is quite a bit of tire for a 9" wheel, would 265 be good.. and then 285 rear?
Old Aug 15, 2008 | 11:51 PM
Jazzer The Cat
Retired Moderator
Sure
You can run a 275 on a 9" wheel by most tire makers, but a 265 is a better fit in my, as well as many others, opinions. The 265 will run about 3/8" narrower and will be more responsive in corners and little firmer ride. A 285 is a good fit for a 10" wheel and would be comparable to the 265 on the 9" wheel in terms of ride and response. Keep in mind, 26mm = 1", so this will help you figure out approx. how wide a tire will be on a given wheel.
Running these on 19" wheels will just give you 1/2" more clearance around fender and tire as well as drop the car 1/2" lower then the 20" wheels. This assumes both the first and second numbers are the same on both sets of tires.
I am not a big fan of 20" wheels on a Stang and really prefer 18"s. 19"s are going to be a good fit. You will likely need to use a tuner to correct speedometer inaccuracy when done. You will loose/gain approx. 5 MPH at 70 MPH as per my own experience with this issue.
Jazzer
Last edited by Jazzer The Cat; Aug 15, 2008 at 11:55 PM. Reason: fat-fingered dimensions.....oops!
Old Aug 16, 2008 | 12:05 AM
EMichael's Avatar
EMichael
thanks for the info.. i currently have 18" polished aluminum bullits from ford on my car.. i plan on getting the saleen body kit for my car and idk if those would go with the kit.. the 19" wheels i'm asking about are the saleen heritage chrome wheels which would probably look better than the bullits
Old Aug 16, 2008 | 12:39 AM
Jazzer The Cat
Retired Moderator
Looks is certainly objective, but I feel as others have mentioned that Bullits are not the best look for the Saleen. With that said, it is YOUR car.
If you put the kit on and decide it looks great........
Jazzer
PS: I just saw your sig, and aren't we all?
Last edited by Jazzer The Cat; Aug 16, 2008 at 12:42 AM. Reason: Jazzer needin' to express himself
Old Aug 16, 2008 | 12:44 AM
EMichael's Avatar
EMichael
haha well like i said idk if the bullits would go with the saleen, thats why i was looking at the 19" heritage wheels but i need to know a good tire size before gettin them.. too bad i can't put the tires from the bullits on the heritage wheels
Tivo304
Aug 28, 2023 12:19 PM
Nov 10, 2015 11:39 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
Sep 8, 2015 06:25 PM
Sep 3, 2015 07:14 PM
