Help which size tires??
What is the best size tire to run on a 17x9 rim and a 17x8 rim. I have 275/40/17 on my current 17x9 rim but i was wondering if this was fiine or do u recommend running a different size???
The size limits of tires are going to be given by the manufacturer of the tire itself.
A 275 will fit a 9" wheel in most cases, but a 265 is a better fit, IMO. As for an 8" wheel, usually a 245 is the largest but a 235 is a good fit.
Jazzer
Jazzer
With a 17" wheel, you are probably going to get no lower than 40 series and will be fine. Keep in mind, that you may see a slight speedometer inaccuracy changing diameter tires. I would expect it to be very minimal going from 275 to 265.
Jazzer
Jazzer
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-08-2015 06:25 PM
M3hunter
09-05-2015 03:42 PM
