LUG PATTERN
Old Dec 18, 2008 | 02:39 AM
refer1's Avatar
refer1
Default LUG PATTERN
Is the Lug pattern on a 94 - up 5 lug the same as a 67-69?
Thannks in advance
Old Dec 18, 2008 | 06:55 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
The 5 bolt pattern of the day was also 4.5", but off-set is much closer to zero. You will have trouble running a modern wheel of any larger width or diameter than stock.
You can run spacers, but creates an issue with lug-bolts that would be too short. You would need to replace them with longer/stronger or use ones with there own bolts, but not a fan of those.
There is a live thread in this section and you will get some additional info.
HTH
Jazzer
Tivo304
Aug 28, 2023 12:19 PM
Oct 7, 2015 07:02 PM
mdg
Oct 1, 2015 07:04 AM
DCole24
Sep 11, 2015 10:50 AM
Sep 8, 2015 11:50 AM
