Different Wheel Sizes
Old Dec 27, 2008 | 10:06 AM
TorinoCobra070's Avatar
TorinoCobra070
Chikn Pharmr
Default Different Wheel Sizes
I'm looking at a car that has deep dishes in the back and not in the front, so obviously the guy is probably running different tire sizes. So to anybody running a setup like this, my question is since you can't rotate them, how unevenly and how much faster do the tires wear out? Thanks.
-Chad
Old Dec 27, 2008 | 10:11 PM
Mike 83 GLX's Avatar
Mike 83 GLX
Depends how you drive. My front tires wear much faster than the rears on all my cars. I take corners (expressway on/off ramps, etc) really hard all the time, but rarely burn the rear tires on purpose. I rotate them every oil change, but still have noticeable wear each time.
If you drive like a normal person and your suspension is in good condition, aligned properly, etc, then your tires should be OK not being rotated.
Old Dec 28, 2008 | 08:47 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
I run a staggered set-up as well as many, including Mike above.
You will VERY likely get un-even wear and not get the most out of your tires. I have found that fronts will usually be dead prior to rears, but not by a whole lot. I too enjoy a good corner and one look at my gallery will tell you JUST how much
If I pro-rate the remaining tread left on tires you are replacing due to wear on fronts, it is worth it to me. BTW, my tires aren't even remotely in-expensive
I say.... go staggered!.... While your at it, go stag too. Even better yet, put the keys away, get a good bottle of tequila and stagger all about the house!
Good times for Jazzer
Old Dec 28, 2008 | 02:10 PM
TorinoCobra070
Chikn Pharmr
Yeah, the look alone is worth a little loss on tire mileage lol, as long as its not a huge loss in tire life.
Old Dec 28, 2008 | 04:18 PM
Jazzer The Cat
Retired Moderator
It all depends on how you drive
Tivo304
Aug 28, 2023 12:19 PM
Nov 10, 2015 11:39 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
Sep 8, 2015 06:25 PM
Sep 3, 2015 07:14 PM
