What drag tires should I use??
Can someone help me decide what kind of tires i should get? for a 69 fastback, 545 stroker, Mostly drag car but i still would like to drive on street on some occasions.
Heres the build list at the moment
Engine Specs
Ford 460 Big Block
Stroke and bore to a 545
Bore 0.030” oversize (4.390)
Original 460 stroke=3.85”
Stroke 545=4.50” (.65 increase)
High flow 72cc kaase P-51 heads Port and Polish with complete stud kit, solid roller cam, steel valves, springs, and rockers
(All forged internals)
Balanced Cast steel Crank with 4.50” stroke
.030 oversized forged flat top pistons
13.7:1 Piston Compression
6.700” Center to Center Length forged connecting rods
.510 lift solid roller cam 280 duration
High performance bearings
Electric water pump/Aeromotive fuel system with tank sump /fan
Oil pressure tune to 70psi
MSD Ignition
Single Plane 1500-6500 RPM Power band Manifold
Edelbrock 750cfm carburetor
Trans
Ford C6 Trans (3 Speed)
SFI bellhousing like Lakewood
SFI flywheel and balancer
High performance clutch/pressure plates/Springs
(Contains manual valve body and transbrake)
3000 Stall Torque Converter
35 spline 9" axles with Detroit locker rear end
Aluminum Drive shaft
1350 U joints
Drive Shaft loops
Suspension and Tires
All wheel disc brake conversion kit
Performance Suspension
1 pair – upper control arms
1 pair – lower control arms
1 pair – coil spring saddles
1 pair – coil spring cushions
1 pair - 1'' lowering coil springs (black powder coated)
Sway bar bushings
Sway bar end links
1'' front sway bar (black powder coated)
1 set strut rod bushings
1 pair of KYB self-adjusting gas shocks (whites)
2 inner tie rods
2 outer tie rods
2 tie rod-adjusting sleeves
Idler arm
Four-link rear end like TCP G-Bar
Sub-frame connectors with cross brace piece
Bergeson integrated power steering upgrade
Front Export brace
Monte Carlo bar
Wilwood disc brakes front and rear
Gut interior
8-point roll cage welded through the floor to the frame.
Engine Specs
Ford 460 Big Block
MSD Ignition
Trans
1350 U joints
Drive Shaft loops
Sway bar bushings
Sway bar end links
2 inner tie rods
2 outer tie rods
Idler arm
Front Export brace
Monte Carlo bar
Gut interior
Dude, your build sounds awsome!!!!! Since you want to drive it on the street occassionally, you'll want drag radials. But, since you obviously have a deep wallet, get a set of slicks for the back, and a set of drag radials for the street. Are you going to race 1/4 mile or 1/8 mile? Hoosiers for 1/8, Goodyears for 1/4. For the street, the new Nitto NT05R is an awsome tire.
Haha thanks. yup the whole build is gunna be about 45k... and yea thats what i was thinking. like 275 drag radials or something. and it will be for 1/4 mile. and goodyears Nitto NT05R tire, those are the drag radials right? what would you recommend for slicks?
My dad runs Mickey Thompson ET Streets at the track on his '66 fastback. He gets great traction, but he is only running 475 hp, sounds like you will be running much more than that. With that kind of power, you might want to invest in a separate set of drag slicks.
yeah, just remember, all that power is no good if you cant put it to the ground. I had to move drag radials to the front of my mod list after a few trips down the track with street tires...and thats only with 300+ horsepower. I would much rather put the money toward other things, but they will just make me spin my tires more...
jwog666
Dec 27, 2021 08:09 PM
KingRando
Oct 2, 2015 08:06 AM
