22mm vs 24mm offset
I have 18x10 black bullits for the rear and need to replace one due to a crack/bend. I can get one fairly cheap. The new one is 22mm offset and the ones on the car are 24mm offset. Will this be a problem or will I even be able to tell the differance?
1" = 25.6mm, so 2mm is a little over 1/16" of an inch. You will never notice it at all
The only difference you may notice woud be the subtle differences between the wheels, as they may be from a different manufacturer.
Jazzer
Jazzer
