tire size question
Old Nov 12, 2011 | 06:41 AM
rfbznb's Avatar
rfbznb
Default tire size question
what is the widest rim and tire i can put on my 02 gt and what offset do i need i like them to be about the hight as the stock 245/45 17
Old Nov 12, 2011 | 07:52 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
You can easily run a set of 17" or 18" wheels with the OEM tire diameter of 25.6", just the profile sidewall is lower on 18"s. Not a problem to run 9" +24mm off-set wheel with 265's up front and up to a 10.5" +28mm off-set wheel with 315's out back.
These off-sets have a slight bit of variable and not be a problem.
Jazzer
NorthAmericanTuning
Nov 9, 2016 11:44 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
Gary Ugarek
Sep 16, 2015 08:04 AM
Mr. D
Wheels & Tires
15
Aug 22, 2015 02:58 PM
