Wheel wobble
Old Nov 9, 2011 | 03:09 AM
Js88lx's Avatar
Js88lx
Default Wheel wobble
Well another issue here.., As i was driving my stang the oerson in the car next to me told me at while at the light the my front wheel (driver) was wobbling. Any ideas what to look for when i check it out later?
Old Nov 9, 2011 | 11:40 AM
mustangsneverdie's Avatar
mustangsneverdie
Make sure that the bearings aren't bad, and that the nut is tight. Also check your ball joint, and make sure it hasn't gone bad.
Old Nov 9, 2011 | 04:51 PM
ttocs's Avatar
ttocs
tell him to pass over to you what ever he is smokin!!! Take two.........
daves not here man!
Old Nov 9, 2011 | 04:59 PM
mattdel's Avatar
mattdel
Rim could be bent too, but probably a wheel bearing.
Old Nov 11, 2011 | 10:31 PM
Js88lx's Avatar
Js88lx
Default horror story
rims not bent!! I will look into wheel bearing after i fix my car!!
Old Nov 11, 2011 | 11:24 PM
mattdel's Avatar
mattdel
Don't say the rim isn't bent unless you just watched it spin on a balancer.
Old Nov 12, 2011 | 01:31 AM
Js88lx's Avatar
Js88lx
True but i have swapped rims and still wobbles. Ill check after i do this clutch cable.
Old Nov 12, 2011 | 08:45 PM
Js88lx's Avatar
Js88lx
well fixed wheel wobble!! Get this., i take wheel off and noticed the following things loose to the touch, disk, shock, caliper, and the turning rod! Basically everything on the drivers side was loose..., cant believe these a holes that sold me car...!
jwog666
Dec 27, 2021 08:09 PM
KingRando
Oct 2, 2015 08:06 AM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
