Correcting speedometer error in wheel changes!
Old Aug 21, 2015 | 10:18 PM
AK_Kayaker's Avatar
AK_Kayaker
Originally Posted by JimC
Sorry but you won’t find (or “fine” sic) such a tool. The speedometer is built into the tuning parameters. So the only way to change the speedometer is to go into the tune and adjust what the computer is reading.
Wonder what happened after 2010, cause Hypertech, Ford Racing, and others made various speedometer recalibration tools, but none are listed to work after 2010 model year.
To bad the OP can't just find some 18" wheels he likes so he could get his more cushy sidewall height, without the hassle of trying to fix the speedo.
Old Aug 22, 2015 | 01:37 AM
SYMBOLISM's Avatar
SYMBOLISM
hey does anyone know if there is a significant speedometer difference going from a 235/55r17 to 245/45/r19? I have a 2005 gt. I have a set of the 2010 mustang oem upgrade package 19s on my car now
Old Aug 22, 2015 | 02:12 AM
AK_Kayaker's Avatar
AK_Kayaker
Well the short answer in 235/55/17 =27.177"
while the 245/45/19 =27.68" just over 1/2" taller
would be better to go with a 255/40/19 = 27.03 so about an 1/8" shorter
That is all.
Old Aug 22, 2015 | 03:50 AM
Mr. D's Avatar
Mr. D
Any recommedations for an inexpensive OBD Tool that I can use to correct speedo readings? Thanx in advance for any help!
Old Aug 22, 2015 | 11:21 AM
JimC's Avatar
Super Moderator
Maybe you missed the other posts that answered your question.
Old Aug 22, 2015 | 02:58 PM
Mr. D's Avatar
Mr. D
Originally Posted by Derf00
Wheel size has nothing to do with it, tire height (diameter) does. You can have an 18" rim and a 20" rim with an overall tire height equal to each other and you would see no difference in your speedo.
If you do get a tire with a different height then yes, a simple adjustment via a handheld tuner is what is needed.
Here's SCT's instructions for example: http://www.sctflash.com/PDF/64Options.pdf
Your dealer is probably strictly by the book so they won't even mention an aftermarket device like the SCT tuner to access the ECM for the adjustment.
Thanks for the help! Appreciated!
mtgldr
Feb 3, 2024 09:00 PM
articman
Jun 21, 2018 11:45 PM
Manny92392
Oct 5, 2015 11:39 AM
zanemoseley
Sep 6, 2015 12:58 PM
