shelby hood pins????
Old 04-18-2013, 07:55 PM
josh87
josh87's Avatar
Default shelby hood pins????
ok so I order the shellby hood pins off of AM. well I have a aftermarket hood trufiber with the ram air and vents. I need to know if anyone has put the pins in and how and where they did it. I would like to try for this weekend. thank you for you help.
josh87 is offline
Old 04-18-2013, 09:38 PM
steel pony
steel pony's Avatar
Here you go...
These are the Scott Drake ones (same as the Shelby's w/o the wording)
steel pony is offline
Old 04-19-2013, 07:33 AM
D'prived
D'prived's Avatar
If you look under the hood and locate the two outer most bump stops... I've seen guys pull those bump stops out and install the hood pin shafts in that place.
D'prived is offline
Old 04-19-2013, 09:58 AM
josh87
josh87's Avatar
Thanks guys. How hard was it to drill in the hood?
josh87 is offline
Old 04-20-2013, 09:33 AM
D'prived
D'prived's Avatar
Not hard at all... Check this out...
https://mustangforums.com/forum/2005...d.html#3876208
D'prived is offline
PaulH2
20
01-31-2016 09:48 AM
Bokeo
10-10-2015 08:28 PM
Urambo Tauro
10-05-2015 09:37 PM
GT350 S550 Tech
09-29-2015 03:29 PM
mungodrums
09-28-2015 10:54 PM
Quick Reply: shelby hood pins????
