Sponsored by:
Sponsored by:
WHICH GEAR TO PUT IN MY 05 GT? 3.73 OR 3.90 OR 4.10
Old 09-02-2006, 10:52 PM
  #51
Stang Skeleton
Stang Skeleton's Avatar
Default RE: WHICH GEAR TO PUT IN MY 05 GT? 3.73 OR 3.90 OR 4.10
ORIGINAL: 1BADD05
ANY HELP HERE GUYS? WHAT GEAR COMES STOCK IN THE 05 GT'S MANUAL? I THOUGHT IT WAS A 3.55, BUT HAVE BEEN HEARING DIFFERENT? PLEASE HELP!
The stock 05 GT manual comes with 3.55s.
Stang Skeleton is offline
Old 09-02-2006, 11:00 PM
  #52
Stang Skeleton
ORIGINAL: androdz
Guys I still am not sure on which gears to get. I plan on supercharging my car in the long run at 9-12 psi. I am not sure on which gears will be better with the supercharger 3.73 or 4.10. I see alot of talk of 4.10 but some guys have told me that I will loose my 1st gear with the supercharger if I get the 4.10s. I have a 2005 gt 5 speed. Also does anyone know if the gt500 uses the same motor mounts and the regular gt?
Att. Andrew
It depends on your particular application. If you plan on using your car on the street and want to mantain driveability, definitely go with a 3.73 if your going to be running a SC with 9-12 psi. It will not be practical at all with a 4.10 and 9-12 psi on the street or on the track because you wont ever be in 1st gear.
Old 09-05-2006, 02:39 AM
  #53
RodeoFlyer
RodeoFlyer's Avatar
with a blower I would stick with the 3.55's
4.10's will make first gear useless. with traction issues you will spin like crazy and waste all the power that the blower makes. The 3.55's will keep you in the powerband longer.
05-06 GT manuals come with 3.55's
07 - up GT's come with 3.31's
for the guy that said these are mustangs, not f-body cars - i said FOX BODY CARS as in 1979-1993 MUSTANGS. learn some mustang history. these arent the first ones
do it right - go with factory ford parts and have them installed at the dealer - they will be warrantied for 1 year/12000 miles. Joe Blow Racing Shop wont give you that
RodeoFlyer is offline
Old 09-05-2006, 06:13 AM
  #54
Remrats1234
Remrats1234's Avatar
4.10s for automatic, 3.73 for auto
Remrats1234 is offline
Old 06-04-2007, 12:57 AM
  #55
lighthero
lighthero's Avatar
How exactly do you check what gears you have in your vehicle (besides pulling them out and looking at them) if you bought a used/modded Bullitt?
lighthero is offline
Old 05-21-2009, 04:23 PM
  #56
stealth_GT
stealth_GT's Avatar
bump for great info on gears/high stall converters.
stealth_GT is offline
Old 05-22-2009, 03:56 AM
  #57
07 GT E UPP
07 GT E UPP's Avatar
Originally Posted by 1BADD05
YEA GUYS I HAVE A MANUAL, GETTING READY TO GET BETTER TIRES ALSO, BUT USE IT AS KIND OF A DAILY DRIVER BUT IT IS PARKED NOV-MAR (MICHIGAN WEATHER) DRIVE SOME HIGHWAY SO WAS WONDERING IF THE 4.10 WAS TOO BIG? I HAVE HEARD 4.10 SHOULD NOT BE PUT IN A DAILY DRIVER? IS THIS TRUE? THX FOR ALL THE INPUT SO FAR.
Garbage, and not true...!!! I have a daily driver (N/A) and do about 80 miles per day (65% highway 35% city). The FRPP 4:10 gears (part # M-4209-G410A) are great and are definately the way to go with a 5 speed. My Tach shows a very reasonable 2425 rpm's in 5th gear going 70 mph on the highway. You will be fine with 4:10's...!!!
07 GT E UPP is offline
Old 08-11-2009, 05:01 PM
  #58
Bmr4life
Bmr4life's Avatar
Bringing up an old thread, but ~2425rpm at 70mph is high. What are you doing at 75 and 80mph?
I drove my car around some with the OD off and it was doing around 2900rpm at 70mph. Didn't like it at all. Sounded high pitched and you could hear the engine over the exhaust.
Bmr4life is offline
Old 08-12-2009, 04:32 AM
  #59
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
TTT....
mygt500 is offline
musnicki
09-23-2015 07:11 AM
Pyrate Dave
09-10-2015 07:30 PM
raleigh05GTO
09-04-2015 07:09 AM
09-03-2015 07:14 PM
Quick Reply: WHICH GEAR TO PUT IN MY 05 GT? 3.73 OR 3.90 OR 4.10
