Sponsored by:
Sponsored by:
Any regrets with the 4.1's
Old 04-10-2005, 01:51 AM
757GT
I ♥ Acer
757GT's Avatar
Default RE: Any regrets with the 4.10's
3.90s turn about 2900 at 80.
757GT is offline
Old 04-12-2005, 12:40 AM
don_w
I ♥ Acer
don_w's Avatar
Here is a formula for determining the rpm your engine will be at for a given speed:
RPM = GR X MPH / Dia / .002975 (GR is rearend gear ratio; MPH you make up; Dia is rear tire diameter in inches - let's assume 26.5" here)
For example: 3.73 X 80mph / 26.5" / .002975 = 3,785 rpm
Or, 4.10 X 80mph / 26.5" / .002975 = 4,160 rpm
However, that calculation would work for 4th gear (1 to 1 ratio) but not with overdrive. With a 5-speed automatic, 5th gear is 0.75 OD and the manual has a 0.67 OD. So, multiply your OD times the rearend gear ratio to come up with the final gear ratio, as follows (for the automatic):
(3.73 X 0.75) or 2.7975 X 80mph / 26.5" / .002975 = 2,838 rpm
(4.10 X 0.75) or 3.075 X 80mph / 26.5" / .002975 = 3,120 rpm
Personally, I'm liking the idea of 4.10s even better now. I can still make the 300-mile cruise to Las Vegas without a problem (except for maybe a speeding ticket or two).
don_w is offline
Old 04-12-2005, 12:43 AM
silverbullit05
silverbullit05's Avatar
personally i am not going to swap gears till i get a 6 speed so i can still have some good top end and a low end as well. just me though.
silverbullit05 is offline
Old 04-12-2005, 06:18 AM
n4ggs
n4ggs's Avatar
how about a 5.0 rear diff and the top 3 gears are all overdrive!
n4ggs is offline
Old 04-13-2005, 01:42 PM
kcshaner
kcshaner's Avatar
Anyone with the 4.10's notice a differnece in MPG.....please share your findings
kcshaner is offline
Old 04-13-2005, 02:08 PM
Loomis
Loomis's Avatar
I have noticed a big drop in gas mileage. At 80 I am running 3k RPM. But I wouldnt havent any other way.
Loomis is offline
Old 04-13-2005, 04:21 PM
td1320
td1320's Avatar
ORIGINAL: kcshaner
I have gotten a best of 24 mpg and average between 22 and 20. I turn 3000 rpm's at 80 mph as well. Mine is a daily driver. I have 10,000 miles on mine since mid November 2004.
td1320 is offline
Old 04-13-2005, 04:33 PM
Loomis
Loomis's Avatar
ORIGINAL: td1320
ORIGINAL: kcshaner
WOW I want your MPG I average 13.
Loomis is offline
Old 04-13-2005, 04:50 PM
td1320
td1320's Avatar
ORIGINAL: Loomis
ORIGINAL: td1320
ORIGINAL: kcshaner
I've never gotten less than 17 period. You need to put your right foot on a diet.
td1320 is offline
69MustangCoupe393cid
10-03-2015 10:33 AM
kdryan
09-29-2015 10:39 AM
05blackstang
04-25-2007 12:39 AM
Stewart
03-29-2006 10:44 PM
chrisc
11-15-2005 12:05 AM
Quick Reply: Any regrets with the 4.1's
